Connection of a Type K Thermocouple to the NI USB-6000
Hello everyone,
I'm planning to connect a Type K thermocouple to an NI USB-6000. However, based on my research, it seems to be a bit challenging.
I’d like to ask if anyone here has experience with this setup.
What would be the proper method to connect the thermocouple, and how can I accurately read the temperature values?
Thanks in advance.
(350 Views)
Thermocouple voltages are small and relative to the cold junction voltage. Easiest would be to to get a thermocouple amplified that includes cold junction compensation and outputs a scaled voltage. They are cheap.
(326 Views)
Reading thermocouples is not as simple as reading an analog voltage.
Here's some information that might be relevant The Basics of Thermocouples
The USB-6000 is not designed to directly read thermocouples as it lacks cold junction compensation.
=== Engineer Ambiguously ===
(300 Views)
