Context help in LabVIEW truncated to 8000 characters.
How to get more details?
Message 1 of 8
(4,474 Views)
Don't you think 8000 characters is a lot for context help? I use just one or two sentences in my context help. If you're overshooting it, probably you should considering making detailed help and link it to a chm file and use the documentation option of the VI to link to it.
Message 2 of 8
(4,460 Views)
Why you are thinking it as a lot? Smiley Surprised Why shouldn't it contain bit more Smiley Wink
Actually am using some drivers for the Tektronix scope. You see in the above picture that the detailed help option is grayed out and no link for detail help. Smiley Sad
Message 3 of 8
(4,456 Views)
Hi Mathan,
Are 8000 chars not a novel by itself... ?! Smiley Wink
- Partha ( CLD until Oct 2027 🙂 )
Message 4 of 8
(4,455 Views)
parthabe wrote:
Hi Mathan,
Dear Partha, you will not say so when you look at the image in my first post where the help displays about just 28 values the variable can take and actually it is 40 and where can i get the info of the extras?
Message 5 of 8
(4,450 Views)
Accepted by Mathan
go to VI properties and check out its tip and description, it probably should have all the text. Hope it helps.
Message 6 of 8
(4,447 Views)
Thanks Nitin, Will have a look at it and get back.....
Thanks a lot,
Mathan
Message 7 of 8
(4,440 Views)
Are 8000 chars not a novel by itself... ?! :smileywink:
LOL!!! :smileyvery-happy:
Message 8 of 8
(4,425 Views)
