Continous pulse output with jitter only?
Using CVI5 and NIDAQ 6.51 on Win9X I try to generate a continous
waveform output on the analog output. One application is sending a pulse
to flash a lamp (1% duty cycle).
We are observing a strange 'jitter' on the pulse width although there
is no update from the program. The amount of change and its 'frequency'
depends on the system (PC, DAQ Card...). Strange enough it gets worth
when there is no data acquisition at the same time.
Is there a proper solution to eliminate this problem?
Has anybody written a continous pulse generator using on board timers
with NIDAQ/CVI or LabView?
Thanks for any help
Urs
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,464 Views)
ursb@my-deja.com wrote in <8k1con$hn6$1@nnrp1.deja.com>:
There are some considerations to be made when doing analog out (under
LabVIEW) at least. It might be that you are observ
ing the reset of the
board since (under LabVIEW) you can set up acquisition at easy,
internediate or advanced levels. Usually the easy/intermediate levels can
re-initalise the board or be basically doing a "once off" each loop
iteration. Check out the examples on buffered analog out which is
effectively what you are trying to achieve.
Hope this helps (unlikely since you are using CVI, but ...)
Alex.
Alexander C. Le Dain, PhD
ICON Technologies Pty Ltd
http://www.icon-tech.com.au
(3,464 Views)
In article <8F6A9898Caledainupnawaycom@192.168.1.7>,
pulse
there
'frequency'
worth
> LabVIEW) at least. It might be that you are observing the reset of the
can
> Alex.
Alex,
I do use CVI , but it is much more a (Ni)DAQ problem, isn't it?
The problem was 'solved' (driven around) by using on board counter which
can be programmed and DO work on their own.
I use the analog output in various projects as waveform genberators. I
set the parameters, download the waveform data and set the output length
to infinite. To my understanding it should run then for ever and with no
glitches, jitter and things like. In reality the card seems to fetch
data from the PC regularely and this causes the mentioned problems.
With faster cards and PC's the problems are less visible.
Does buffered analog out help?
thanks
Urs
Before you buy.
(3,463 Views)
ursb@my-deja.com wrote in <8kbt6n$4b1$1@nnrp1.deja.com>:
It sounds as if you are doing it the same way I would under LabVIEW and
presumably this is the correct way. Have you checked out whether there are any
solutions in the Knowledgebase on the NI web site? I have found that sometimes
there are solutions ther
e that help - especially if there is a limitation in
some area. Sorry I cannot be of more help.
cheers, Alex.
(3,462 Views)
