Continuous output to DAQmx and software queue
I am trying to output a digital waveform on a DAQ card using the internal clock. Now, I would like to also store the waveform for further processing using the accurate times at which the waveform was written. So I would like to get a waveform back which allows me to know in which state my digital output was at a given time.
Is there an option to do this?
Or, as an alternative, could I somehow synchronise the start of the waveform output to the DAQ card with a timed loop? Since I know the waveform that is written, that loop could e.g. return that waveform with the proper 't0' for each iteration.
The code is running on an RT-target.
Background: I am controlling an instrument which has no readout of its current state but I would like to record its current state based on the control input.
(3,858 Views)
Maybe you can use "start trigger VI" for starting your task in the given moment?
And then you know moment of start (t0) and dt from task timing.
(3,826 Views)
Accepted by topic author ehrlich
After some more digging, I realized that there is a "DAQmx Create Timing Source" VI that returns a timing source synchronized to the Sample Clock of the DAQmx task. This timing source can be used as a timing source for a timed loop. There is an example for that here:
https://decibel.ni.com/content/docs/DOC-25763
Unfortunately, I realized that my digital I/O hardware has no hardware timing capabilities so this also doesn't work for me and I have to stick to a software timed solution.
(3,787 Views)
