Continuous serial communication.
I am continuously receiving an ascii string from the Visa read i want to convert it to a hexadecimal. In this i want to start store from some hex like 5A if i found 5A in the string i need to store 5A along with the next 10 string characters to an array if i again found that 5A i need to start store along with the next upcoming 10 string characters. I anyone have some solution on this kindly help me to solve this
Message 1 of 17
(4,294 Views)
Hi Rajsakthi,
What have you tried and where are you stuck?
What's the problem to search for a char inside a string and to take a StringSubset?
Message 2 of 17
(4,274 Views)
 can you please guide me to achieve continuous ascii string to convert to hex string.
Message 3 of 17
(4,258 Views)
I need the substring as 5A A5 2B 00 D1 FF 2F 95 30 6C
Message 4 of 17
(4,244 Views)
Hi Raj,
mind to share your VI with same real data in the frontpanel elements set as default value?
We cannot debug/edit/run images in LabVIEW!
(Please downconvert (File->Save for previous)  to an older LabVIEW version when you use a recent one. I prefer LV2019.)
Message 5 of 17
(4,242 Views)
i am using labview version 2015 will it supports to you.
Message 6 of 17
(4,238 Views)
I am in working place so it is not possible to share the file.
Message 7 of 17
(4,229 Views)
Hi Raj,
So you need to debug on your own...
Why do you even convert to hex-formatted string instead uf using the byte array delivered by VISARead? No need for this conversion (at this time)!
Use StringToU8Array and Search1DArray to search for 0x5A (=0d90), then use ArraySubset to get your data...
Message 8 of 17
(4,218 Views)
Assuming you already have your data as a numeric array. Just search for the value you want with Search 1D Array. For the next value, start from next index after your array. 
Message 9 of 17
(4,202 Views)
Can you please share this as a VI file.
Message 10 of 17
(4,198 Views)
