Continuously build and display 2D data
I have a 2D profile data set and i'm able to display one profile at a time just fine.  What i'd like to do is buffer the data set to show (Y) number of scans of an object at (X) length and (Z) color ramp.  I can't figure out how to build a contour plot, any help would be greatly appreciated.
(3,323 Views)
I'm not sure exactly what you are after, but the intensity graph or chart might work for you.
Could you post a picture of what you want the graph to look like, and we can tell you how hard it will be to create it?
(3,322 Views)
Yes, you are mixing in quite a few very ambiguous words ("2D profile", "contour plot", "continuously", "object", etc.)
Please attach a simplified VI containing some typical data for one profile and how you expect it to look like for a set of profiles. Should they be averaged, appended, overlayed, etc.)
(3,307 Views)
Here is a simplified VI that displays (1) profile per iteration of the For loop.  I'd like to create a plot where my (Y) axis is the number of profiles, the (X) axis is the individual point spacing of the data and a color ramp that represents the (Z) height data.
I can't seem to figure out how to store multiple profiles to build the Intensity plot.
(3,261 Views)
Accepted by topic author coolhandLV7
To retain data between iterations, you need a shift register. Here is a simple example. Modify as needed.
(Note that the intensity graph is set to "transpose")
(Of course this example is probably too simple, because eventually you'll run out of memory. :D. If you know that there will only 10 profiles (you originally used a FOR loop with 10 iterations!), you could initialize the full 2D array into the shift register and replace rows as new profiles are acquired)
(3,255 Views)
Thanks I was able to do this by changing the tunnel mode also.  The real problem was the data format my "real" program is all out of whack so i need to clean up the format so that it makes sense.
(3,252 Views)
A shift register is not really a "tunnel". If you don't need to see the data as it builds, you can of course create the 2D array at an auto-indexing output tunnel instead. I was under the impression that you want to see the graph updated live, especially since your loop time was 1000ms.
(3,246 Views)
