Continuously update formula node
I have created a formula node, and one of the variables is connected to a DAQ assistant by means of a 'from DDT' which converts the dynamic data to the latest value. However, I want my formula node to continuously update the output if the input from the DAQ assistant changes. Right now it only takes the value from the moment I press 'run'. How do I get my formula node to do that?
(4,743 Views)
Accepted by Allard171
Put everything in a while loop and check if the last value is different from the new value. if true run your code in a case structure.
(4,738 Views)
Could you please share a photo of your code? I have the same issue..
(3,768 Views)
