Control Design and Simulation palette doesn't appear
I'm using LabVIEW 2009 in Professional License. I've installed Control Design and Simulation Module with its all other required Toolkits. The problem is that Control Design and Simulation palette  doesn't appear in the Functions Palette in any VI. Please help me with that.
Adeel Amin
NED University of Engineering & Technology
(6,498 Views)
Accepted by Adeel_el15
If you run NI License Manager, Expand LabVIEW2009>Modules>Control Design and Simulation.Can you verify that you have that directory and what is the color of the cube right next to it?
Andy Chang
(6,489 Views)
I have installed labview 2017 licensed version. But I don't have control control design,simulation.How to add it. I have only 2 options under control and simulation.
(5,077 Views)
Hi SSG0484,
Please make sure that you have installed the Control Design and Simulation 64 bit since that is the LabVIEW version that you are loading (according to your screenshot)
Sil.VI
(5,072 Views)
I have the same issue with 32-bit LABVIEW and 32-bit Control and Design Module installed still in the Control & Design pallet these are only two options, PID and Fuzzy logic.
(1,720 Views)
