Control MAX through labview
Is there any way by which I can control and make selections in MAX through labview code?
I need to select driver sessions for IVI classes of instruments. For this it will be good if I can create IVI classes and select driver sessions programatically using labview.
Any take on this?
(3,374 Views)
any suggestions folks??..
(3,313 Views)
The closest thing to a programmatic API for MAX is the NI System Configuration API, however I don't think that you can currently use it to configure IVI settings.
(3,298 Views)
No, you cant use any existing API to programatically adjust IVI config settings.
However, all of these settings persist in "XML-Hell."  With the right file manipulations,  regisistry entries and / or details on what, if any, services need to be triggered to update it is THEORETICALLY possible.
Spoiler
I Wouldn't try it without serious NI involvement.  There is almost certainly a better way to get what you want.
(3,288 Views)
(3,276 Views)
