Control Mouse Movement
Is it possible to programmmatically control the position of the mouse cursor?  I would like to program the mouse cursor to return to a specific point on the front panel once the user has clicked on one of any six boolean buttons.  This will need to happen several hundred times during the duration of the program.
(3,508 Views)
You would need to use the API appropriate to whatever operating system you are using. If you perform a search on this forum for "set mouse position" or "set mouse location" you will come across several examples.
(3,479 Views)
