04-18-2007 06:43 AM
04-18-2007 08:20 AM
04-19-2007 12:43 AM
Excellent Nick.. Thanks for the info.. I have not yet excxplored LV 8 much...
Regards
Guru
08-12-2008 02:31 PM
08-13-2008 04:19 PM
Hi tsksesa,
There seem to be multiple different possibilities for the source of this error, so try to narrow down what is causing the problem. What are using for your source and destination inputs, and do you get this error no matter what these values are? What product types are you copying? Try to copy a different MAX configuration file, and create a simple VI that only executes this function.
Also, it is easier to keep track of issues and get you answers if you post separate new questions in new forum posts.
Stephen S.
08-14-2008 09:58 AM
Source: system://192.168.1.56 (a real time computer) destination: c:\max.ini , product: daqmx.
With the upgrade to LV 8.6 the error has stopped but a new bug has shown up. If I make a change in the RT systems setup the max.ini that is created will contain nothing but the header
[DAQmx]
MajorVersion=8
MinorVersion=8
The rest of the file being blank. But if I reboot my machine (not the target system) it will then make a good .ini file. I am currently running this in a stand alone vi until I can get it working consistently.
08-15-2008 07:00 PM
Hi tsksesa,
Are you running DAQmx 8.8 or 8.7? If not, upgrade and see if you get the same problem.
08-18-2008 10:15 AM
08-20-2008 08:59 AM
08-20-2008 05:54 PM
