Control Newport XPS Q8 linear translation stage
Sir i tried. I got the need. I didnot use get status. Instead i used wait(ms) in the while loop. Thank you very much for your suggestions. I used relative move inside the while loop. I will contact you when i need further clarifications.
Message 11 of 11
(1,137 Views)
