Showing results forĀ
Search instead forĀ
Did you mean:Ā
Control System Help
Hi guys,
I dont have a lot of experience with labview, I have only acquired a signal. Need to acquire signal from displacement transducer and depending on position, need to control a 4 way soleniod valve that controls air cylinder. have a ni9201 input and ni9481 relay.
thanks!
(4,204 Views)
So what is your exact question? This is not a place to get your homework done. Post your code and explain what your difficulty is.
There are several free tutorials on-line. Have you taken any of them?
(4,190 Views)
This is for a project. I have a LVDT that I am reading an analog signal for position. I want the electromechanical relay NI 9481 to turn on or off at a set analog voltage. I have done some of the tutorials and searched online with no luck.daq assist output want a boolean array as its input (green) our daq assist thata cquires dat produces (blue) data type.        I guess the question is how to populate a boolean array with our processed acquired data?
(4,187 Views)
Surely the tutorials covered a basic comparison? If you use the DAQ Assistant, a simple build array function can convert a Boolean to the required input.
p.s. The ' blue' wire is the evil dynamic data. It can be converted to a waveform with a y array or to a number of other data types. Depends on how you are acquiring the analog signal. For a single sample, you can convert to a scalar.
(4,176 Views)
How do you correlate an LVDT which provides an analog input value to a boolean array?
If you just want a single ON/OFF, TRUE/FALSE boolean value, then you can use a Greater Than or Less than comparison to compare your analog input to some constant that you define.
I suggest doing more than just "some of the tutorials".
(4,174 Views)
where do i find this relay status check block in labview, i cant seem to find it.
http://digital.natinst.com/public.nsf/$CXIV/ATTACH-AEEE-76QSNL/$FILE/CheckRelay.jpg
(4,168 Views)
That's just a boolean indicator that happens to be labeled "Relay Status".
There is nothing special about that.
(4,127 Views)
