Control alignment
I would like to figure out how to align to control properly. I have tried to experiment but I can't see any logic to this.
When I select 2 controls how can I tell Labview which control is the one I want aligned to?
I seem to always get the opposite of what I'm trying to do, one time it will be control #1 next time it is control #2.
What am I doing wrong?
Ron
(3,129 Views)
From my experience the controls will allign to the one that is in the Maximum position.  For example if you do an align top,  the controls will all align to the one that is the highest.  If you have three or more controls spread out at different heights I don't think there is a way to align to a middle control in one step.  You would have to align the higher ones first with align bottom and then the lower ones with allign top.
(3,124 Views)
I guess I'm just used to the way it works in VB.
Ron
(3,121 Views)
