How to creat a lookup table
Hi
I have been looking and trying to figure this out for a few days and after awhile you just head no where.
What I need to do is use a lookup table and change gray code to an angular reading.
I have an 11 bit encoder I am also using LabVIEW 7.1 with a USB-6259. I can read the decimal and the Hex values but just can not seem to figure out how to get the angular measurements that I need. I have attached a simple .vi to get the hex and decimals as well as a .txt file with the gray code any help will be appreciated.
Gerald
(3,492 Views)
Quite easy when you know how to handle array and read from file functions ; and quite hard if you don't 😉
Feel free to ask question if something is not clear !
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,487 Views)
Well I need to learn a lot about the array and all of it for that matter. But with a little changing and studying and trial and error on my part I got it to work. I have attached what I came up with and seem to work very well. I took your .vi and removed what I did not need (after I figured it out) to be displayed and added a few things. I can now see the angle, degrees per second of movement. The only thing I will need to figure out is how to put in a zero button so that it can zero the dial at any point while taking measurements. Thanks for your help I could not have done it with it. Any ideas on the zero button would be appreciated as well.
Thanks you very much!
Gerald
(3,469 Views)
New problem.  Have duplicated the VI and hooked up the second sensor. Sensor 1 still works fine sensor 2 does not. I think the problem is that it is reading 22bit and I only need 11 bit. I have both sensors wired into port0 sensor 1 is wired to port0/line0:10 sensor 2 is wired port0/line11:21.  Is there a way to ignore the fist 11bits (line 0:10) or a way that would work. It shows up as 1100111110100000000000 and a dec. as 3401728. Please see attached.
Thanks in advance
Gerald
(3,440 Views)
