Control and simulation multisim, decimal precision
I'm using labview to simulate a multisim circuit with an input and an output voltage. The voltage comes out of the multisim module and goes into a collector and is written to a text file.The values I receive in Labview have 6 decimal numbers (0.XXXXXX). I need a more accurate reading. Is there a way to increase the precision ? Preferably around 10-12 decimal numbers.
(4,501 Views)
Accepted by topic author MarnixGi
Hi Marnix,
Generic answer: change the formatting settings (of your indicators and file write options)!
More detailed answer: Please attach your VI to receive specific suggestions.
(4,465 Views)
Thanks, it was indeed the format in the 'write to spreadsheet' function. I changed this format to %.12f and everything works now. In case this helps someone else these are all formatting possibilities.
https://www.ni.com/docs/en-US/bundle/labview/page/format-specifier-syntax.html
(4,458 Views)
