PXIe-5442 shows driver has not been associated
I wanted to know what the driver is for the PXIe-5442. I have not been able to locate a driver or what version this module stopped being supported.
(2,647 Views)
It looks like the PXIe-5442 uses something called NI-FGEN, which you show as "installed".  See attached page from the 5442's Manual.
Bob Schor
(2,581 Views)
Thanks. I will look into associating this driver.
(2,575 Views)
Thank you for the input on this. This option is no longer what we would like to use. You can mark this as closed.
(2,510 Views)
