Control another software menu by LabView
Hello everybody,
I got an issue and it's about controlling by LabView another software menu :
-There are 2 open windows (LabView front panel and GenICam software window that captures video images)
-On the GenICam window, it is possible to capture and save an image with the keyboard shortcut Ctrl + I, what I want to do in my Labview code is to order the GenICam window to run this keyboard shortcut automatically.
In summary, I would like to control my Image Acquisition window (GENICAM) from Labview !
I don't capture or save images directly from LabVIEW because this software already supports it, it's just that I want to automate the fact of running the keyboard shortcut by ordering from LabVIEW.
Thank you for helping me 😉
best,
Y_Rif
(4,305 Views)
did you actually search for you problem?
e.g. https://forums.ni.com/t5/LabVIEW/Can-LabVIEW-control-another-program-or-emulate-keys-pressed-on/m-p/...
also is your cam software possibly controllable via commmandline, that might make it easier for you.
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(4,289 Views)
Accepted by Y_rif
If you need just Ctr+I, use Simulate Keyboard Events
(4,285 Views)
Thank you guys !
(4,262 Views)
Did you solve this problem? I do have the exact problem. I would like to know whether it is done. If so, could you share the VI?
Thanks.
(3,893 Views)
Thanks.
You can open link from my post and find the code
(3,883 Views)
