Control desktop PC carrying hardware by laptop
I'm a rookie with Labview. I've done some smaller programs, but that's it.
I have some PCI Labview cards here, for measuring analog, digital, GPIB and so on. Is there a possibility, to use a normal Windows copputer to "carry" this hardware and control everything with a laptop connected by ethernet?
If this is possible, what do I need?
isotta
(2,816 Views)
HI Isotta,
easiest would be to use Windows RDP or VNC (or some other software like those)...
(2,812 Views)
Is there any reason you can't use a PCI expansion chassis rather than a desktop PC?  This is the first thing I found doing a quick Google search.
Jim
(2,809 Views)
the remote desktop solution is such a thing. The reason why I want the split setup is, the hardware needs to be integrated in a measuring system, but I also want to program at home. This speaks against a RDP solution.
First I also thought about a external PCI case, but there's a budget reason why this solution won't work.
isotta
(2,804 Views)
Accepted by topic author isotta
I've never taken advantage of this feature, but VISA supports sharing devices over a network, so you may be able to use some of your devices remotely that way.  See
http://digital.ni.com/public.nsf/allkb/F3AB0B5D7DBA367C86257982005BBF2C
http://zone.ni.com/devzone/cda/tut/p/id/4789
The older "traditional" NI-DAQ driver supported a feature called "Remote Device Access" that would let you use a remote DAQ device, but as far as I know it is not supported by the newer DAQmx driver and no similar feature is available.
(2,798 Views)
Hello and thanks, that's exactly what I was looking for?
(2,784 Views)
