calling executable from block diagram without stopping current VI
How can I call an executable labVIEW-built application from a running VI block diagram without stopping the running VI?
Message 1 of 9
(3,669 Views)
You would have to use teh system exec VI like you would any other external exe. You will not have access to anything like the connector pane of your application.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 9
(3,665 Views)
But this would stop temporarely the caller VI .
Message 3 of 9
(3,663 Views)
Message 4 of 9
(3,656 Views)
You could include this in a small parallel task in your code. This particular task would wait for the external application to complete but your other tasks would be able to run.
Mark Yedinak
LabVIEW Champion
Message 5 of 9
(3,651 Views)
Sorry, but as I'm a beginner, would you tell me how to add a 'small parallel  task' to my code? Thanks alot.
Message 6 of 9
(3,642 Views)
The easiest way is to create two While loops on your diagram. These loops should be next to eacho, not one inside the other. Also, there should be no wires connecting the two loops. It is OK if you have a wire branched as inputs to the two loops but you should not have the output of one wired to the other loop. The code in each While loop will run independently of each other.
You can look at the examples that ship with LabVIEW for producer/consumer and parallel tasks for more information.
Mark Yedinak
LabVIEW Champion
Message 7 of 9
(3,633 Views)
Thank you for your help. I'm done with this but I guess I will bother you again very soon ... if you let me.
Message 8 of 9
(3,616 Views)
Then mark Mark's post as the solution to your question rather than your thank you message to give him proper credit.
First you will need to go to the options menu to the upper right of your message to unmark it as the solution.
Message 9 of 9
(3,604 Views)
