Control methods - 6i bug?
Dear list,
I've got this problem.
I want to set prgramaticly a boolean control to it's default value (off).
I use the create->invoke node-> methode reinit to default.
When the program runs in the developer environment, it works fine. The
control is set to it's default value. When I make an exe-file with the
application builder it doesn't work. The control isn't reset to it's default.
I've upgraded to 601, but it doesn't help.
Any suggestions?
Andreas
(2,992 Views)
There was a thread about a week ago that covered this. Look for "Set arry
of controls to default".
"AndreasC" wrote:
>>Dear list,>>I've got this problem.>I want to set prgramaticly a boolean
control to it's default value (off).>I use the create->invoke node-> methode
reinit to default.>When the program runs in the developer environment, it
works fine. The >control is set to it's default value. When I make an exe-file
with the>application builder it doesn't work. The control isn't reset to
it's default.>I've upgraded to 601, but it doesn't help.>>Any suggestions?>>Andreas>
(2,992 Views)
