Labview 5.01 and Instron machine
I'd like to connect Labview to Instron machine to measure strain. How am I
supposed to connect strain guages to SCXI 1200 and SCXI 1322 terminal block???
Do I have to buy another data aquasition module to do it???
(3,606 Views)
I'm trying to remember how those things work. IIRC, the resistance
changes with strain changes. Perhaps you could use a current signal with
a constant voltage supply that would result in the current changing with
the resistance changes? Of course, you would have to do some calibration
work.
Harry
(3,606 Views)
As I recall, the 1322 is a strain gage and pressure transducer front end for
the SCXI unit. It supplies excitation and has a potentiometer balance the
circuit and null lead loss,etc. There should be a scxi module that the 1322
connects to. then the scxi box is connected to the 1200 card by a cable.
Did you try calling NI?
Thomas wrote in message <38757a16@newsgroups.ni.com>...
block???
(3,606 Views)
The SCXI-1322 is a terminal block that is used to connect signals to an SCXI-1122. An SCXI-1122 is intended for use with transducers that need either voltage or current excitation such as a strain gauge or RTD. The SCXI-1200 is simply a digitizer and does not provide excitation. Also, the SCXI-1200 will not interface with an SCXI-1322.
(3,606 Views)
