Control of a JULABO cryothermostat (CORIO CD) using LabView
Dear NI forum members,
I would like to control a cryothermostat (JULABO CORIO CD) using a labview program.
There is a driver made available by JULABO with some examples (Software | JULABO GmbH). It was released in 2012.
I have one of the latest version of LabView (2024Q1) and I am using the 32 bits version since I have some compatibility problems with equipment I control with LabView.
The examples provided do not work. The thing is that I have to put the "external control" of the cryothermostat to ON to make it controllable and when I start the LabView program, it goes back to OFF instantly and nothing happens.
When I used the Windows program also provided by JULABO (EasyTemp, Software | JULABO GmbH), it is working perfectly (but unfortunately, it's not as tunable as a LabView program can be). So I think this is clearly possible and it might be a matter of wrong connection between LabView and the cryothermostat.
But I'm no expert at all, so I need your advices!
Also, I used MAX to try to find where the problem is. I reconfigured the virtual COM port exactly as specified in the Labview examples and I receive this answer:
Is port connected VI_ASRL_CONNECTED Invalid Property Value
What should I do?
Should I try all possible configurations (Baud rate/Flow control/ Parity/Data Bits/Stop Bits)? It will take me hours...
Any suggestion will be welcome here 🙂
Thanks a lot
Message 1 of 11
(1,458 Views)
Hi lforire,
how do you connect the Julabo to your computer?
RS232, RS485 or USB?
Real COM port or USB-to-COM adapter?
Message 2 of 11
(1,445 Views)
Sorry I forgot to mention. I am using a USB cable on both sides (PC and cryothermostat).
Thanks!
Message 3 of 11
(1,442 Views)
Hi lforire,
how does the VISA resource string look like?
Does that USB connection create a virtual COM port? (I guess so.)
Can you communicate with your device using a terminal tool (like HyperTerminal)?
Message 4 of 11
(1,424 Views)
Yes, I've attached a picture of the VI.
yes a virtual port COM5 is created.
Thanks for the suggestion HyperTerminal, I'll try that.
Message 5 of 11
(1,406 Views)
Hi lfirore,
The VISA resource name is empty: no VISA resource, no VISA communication!
Message 6 of 11
(1,398 Views)
Sorry, I took the screen at the wrong time. Of course, I select the right COM port (5) when I am trying to connect
Message 7 of 11
(1,394 Views)
I have tried Hyperterminal, but I do not know how to use it effectively.
I would like to check what is transfered to the cryothermostat when the EasyTemp program is running, but I cannot access to the COM since it's occupied.
Thank you
Message 8 of 11
(1,385 Views)
Hi lfirore,
you can look into the driver VIs to read the commands send to the device!
Or read the programming manual…
HyperTerm is used as replacement to other software - you learned the COM port is NOT a shared resource!
(There are other tools that allow you to sniff the COM port communication…)
Message 9 of 11
(1,377 Views)
Thank you!
I've downloaded another software that allowed me to monitor what's the labview and the EasyTemp programs are doing and I will try to compare.
Thanks for the tip
Message 10 of 11
(1,370 Views)
