Right to Left
Hello everyone,
I'm working with a String Control in LabVIEW, and I've noticed that when I type text into the control, it's spelled from left to right (left-to-right direction). However, I need the text to be written from right to left (right-to-left direction).
Is there a way to configure the String Control so that text input occurs from right to left instead of left to right, perhaps utilizing a value change event?
Any suggestions would be greatly appreciated. Thank you for your help!
I've attached code that does this perfectly in a RichTextBox but I'd like to do it in a simple String Control.
Message 1 of 15
(2,200 Views)
Use the Font dialog (ctrl+0) to set the text alignment to Right.
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 15
(2,183 Views)
It's moving the text to the right side but Does not perform the 'Right to Left' functionality
I've included an example that does this well.
Justify = Right does nothing except change the position of the text
Message 3 of 15
(2,179 Views)
Hi Max,
Even writing this twice doesn't make the attachment appear…
Message 4 of 15
(2,174 Views)
Oops...
Message 5 of 15
(2,171 Views)
Hi Max,
when using recent LabVIEW versions you should consider File->Save for previous.
(Most recommend to save for LV2021 or older, I prefer LV2019.)
Message 6 of 15
(2,160 Views)
Ah, then i understand. Try this:
Qestit Systems
Message 7 of 15
(2,121 Views)
Is this a language thing?  Maybe this is better handled through localization?
Bill
CLD
(Mid-Level minion.)
Message 8 of 15
(2,118 Views)
If it is a language issue (I can't look at your code right now), then that (or something simpler like a TextBox) is indeed your solution. Microsoft have put some effort into getting bidirectional support in their text controls and NI has not really done it, so you can type R2L text, but it doesn't play nice with punctuation, numbers, English, etc.
___________________
Try to take over the world!
Message 9 of 15
(2,077 Views)
I am interested in writing a sentence that combines English and Hebrew without it being scattered
Message 10 of 15
(2,041 Views)
