Control palette not available
I am trying to go through some LabVIEW tutorials, and I am unable to access the Controls Palette.  When I click the View menu, the Controls Palette option is in greyscale and I cannot select it.  Any ideas as to why this is so?
(4,815 Views)
The easiest way to get to the Controls Palette (for use in the Front Panel) and the Functions Palette (for use in the Block Diagram) is by right clicking.  When you in the Front Panel the Functions Pallete will be disabled (greyed out) in the View menu and when you are in the Block Diagram the Controls Pallete will be disabled in the View menu
Mark
NI App Software R&D
(4,791 Views)
