drop control on control refunum
What happens when you have a control refnum on the front panel and you drop a numeric control on top of it?
Cheers!
(3,155 Views)
The control refnum should take the data type of the control you drop into it.
(3,152 Views)
Hi Jmcbee,
Matthew is right, if you want to learn more about Control Refnum, check out this Dev Zone [link removed; article no longer available] on ni.com
Van L
NI Applications Engineer
(3,123 Views)
Thank you very much, this is just what I was looking for!
(3,113 Views)
