Control solenoid valves
Hello All,
I need to control 3 solenoid valves (MHP1-M1H-3/2o-M3-PI), using labview. The activation protocol is like this:
valve1 On for 2 seconds, and then Off for 1 sencond, this should start with pressing a bottom and stop after specific number of on-off cycles (for example after 100 times on-off), again with bottom.
valve 2 and 3 have the same protocol, but they should start after a 'delay=1 second' respectively after eachother.
Since I am a new user to Labview, could you please help me how I can programm these tasks.
 I have attached the task description.
Thank you very much.
(3,931 Views)
You've forgot to attach the description. And why don;t you try something or atleast come up with a flowchart.
You for trials, you can possibly use LED's on the front (representing the valves) as shown below.
Three valves
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,921 Views)
Sorry I tried to upload the descrption but failed.
(3,912 Views)
State machine, https://www.ni.com/en/support/documentation/supplemental/16/simple-state-machine-template-documentat... would be an architecture that would fit to your requirement.
(3,821 Views)
