Labview absolute time waveform chart to excel
Hi everyone, I have a bit confusing on absolute time waveform chart. My problem is when I want to export to excel, the data duplicate nearly 30 times for each second. My project is about collect temperature from serial port and plot it in waveform chart, and I want to view history data in excel.
Anyone can help to solve my question? I attached my vi here..
Thank you so much..
(2,699 Views)
You are getting such a large number of readings because your VI has no timing control in it, if you simply add in a delay somewhere of maybe migrate to an event structure with a timeout then you can control the number of readings that are taken per second.
(2,655 Views)
