Control that sets Array of Cluster size
Hallo,
I'd like to have a numeric control for the user that allows him to change the size of a control array (of clusters). Is that even possible?
Not control just the displayed as in "Number of Columns", but deactivate the clusters that have N higher than # on the numeric control.
Message 1 of 11
(6,456 Views)
Hi spinelli,
sounds like you need a numeric control wired to the length input of the ArraySubset function to limit the number of array elements...
Message 2 of 11
(6,451 Views)
It works for the programm, but the user do not see those deactivated cells as deactivated. I would need something that shows that to the user.
Message 3 of 11
(6,414 Views)
Hi spinelli,
when you limit the array size as described above (and refresh the control with the size-limited array, of course) the user will see the deactivated elements.
Btw. I would call such an approach a "bad user interface".
Why not limit the possible user inputs so (s)he can only access allowed array elements?
Why use an array control at all in the UI?
Message 4 of 11
(6,411 Views)
It seems that it will work. But how do I refresh the control array?
And I need the array size to be defined by the user. The number of elements represents the number of robots on the line, and the information inside the array are the proprierties of each robot.
Message 5 of 11
(6,408 Views)
Accepted by spinelli
I'm not sure if the vi of re-initialing array size is what you want?
btw, who can tell me why I cannot upload the *.vi file?
Message 6 of 11
(6,406 Views)
Hi spinelli,
- "refresh" means: writing the current data into a local variable of the control.
- The user may still define the array size. But: you can make a UI, where he only has access to one array element to change the parameters. The user has to select which element to process - and that selection can easily be monitored to allow only valid elements. See this as an example:
On the left side you see a table that shows all possible elements (here just one). You can select an item to edit it's properties on the right side of the UI...
@Will: this is an old problem...
Message 7 of 11
(6,404 Views)
Will, it worked, thanks a lot. That was exactly want I needed. The only problem left is that when I change the value in "Numeric" it resets all the values in the array to initial. Can I store the data in the array to avoid the problem?
Message 8 of 11
(6,387 Views)
Gerd, thanks for "refresh" explanation, I didn't know it was possible! But I still don't get it with the image you've sent. Where do you go to this configurations? Can you send me the VI or the problem with uploads is for everyone?
Message 9 of 11
(6,383 Views)
Hi spinelli,
the shown frontpanel is of a VI made for our testbench software. I can't send you the VI for several reasons (copyright, heavy linkage to my user.lib, ...).
It's just an example to show you a way, how to present an array of settings to the user - without showing the underlying array itself...
Message 10 of 11
(6,381 Views)
