Control values converted to bit codes
You can add more bits by simply adding more booleans to the cluster.  As I said, all datatypes must be the same for the cluster to array to work.  I think your listbox is the "proper" way to do this since only one selection is valid.  You could use a ring as well and assign it the proper values as you did with your TTLAPI_OPENCONNECTIONS_CMD_BITS.ctl.
I didn't note that typcially using a function node is slower than using the primitives.  I relaize for a text programming person, it's difficult to use the primitives because it takes up more room and glancing at it doesn't make it clear.
Message 11 of 11
(520 Views)
