Controling 2 Markers on Slider
I have a slider with two markers (see file attached).
This slider is used to select an area of datas to analyse.
The pb is that I don't know how to control the slider so that the operator can't move the first marker position after the second marker (and second marker must never been lower than first).
Thanks.
Eddy DUCHENE
12 F Chemin de Boutary
69300 CALUIRE ET CUIRE
educhene@laposte.net
(2,798 Views)
HI,
i have just tried to modify it for you so that SL1 does not cross SL2 see if it helps
(2,798 Views)
thanks for your response;
at the end, it is the result I would have : but the Vi does not resolve entirely the pb : you can always move the first marker after the second (IHM and see the red color from beginning of the slider to the second marker) , even if after, when the operator release the mouse, position of the two cursors are same.
I don't know if there is a solution to prevent the operator to move the first cursor after the second (and second before first of course) by IHM ????
Eddy DUCHENE
(2,798 Views)
