Controling Y-axis
Hi
I have an XY Graph with multiplie Y axis.
Is there any way i can controll the vivibilitiy of each Y-axis?
Message 1 of 10
(4,587 Views)
Hi torkil,
you already found the property node to switch the visibility of an Y axis. Now you only need to use another property node named "Active Y axis" to select the correct axis...
Message 2 of 10
(4,586 Views)
Thx
Can i also use this metode to change names on the graphs using the property node Y.scales Namelabel.txt?
Message 3 of 10
(4,582 Views)
Instead of writing a message and waiting for an answer you could have tried it on your own...
Answer: Yes.
Message 4 of 10
(4,580 Views)
Im a little slow started today
can u show me exactly how its done ?
Message 5 of 10
(4,573 Views)
Hi torkil,
I use a German LV version, but I guess you get the point:
Message 6 of 10
(4,569 Views)
Vielen Dank rettet den Tag
Du bist ein Genie
Message 7 of 10
(4,567 Views)
My graph acts like an disco light ,anyone got an idea why?
Message 8 of 10
(4,563 Views)
Accepted by torkil
Hi torkil,
what do you mean by "disco light"?
Depending on your YScale1.Visible button the graph is visible or not. Just like you programmed that property node...
Message 9 of 10
(4,560 Views)
Nevermind
I used the wrong visibility option
Message 10 of 10
(4,559 Views)
