Controlling NI-9145 C Series Modules from cRIO-9068 FPGA via Python (nifpga)
Hello everyone,
I am developing an FPGA VI and deploying its bitfile using the nifpga library on a cRIO-9068.
My goal is to control the C Series I/O modules of the cRIO directly from Python scripts via this bitfile.
However, since the cRIO-9068 has only eight slots, I purchased an NI-9145 EtherCAT expansion chassis to increase the number of available slots.
I’ve realized that the nifpga library cannot directly access or program the FPGA of the NI-9145, since it is an EtherCAT slave.
To overcome this, I’m considering using PDOs or shared variables to exchange I/O data between the NI-9145 FPGA and the main cRIO-9068 FPGA.
Is this approach possible?
Or are there any alternative ways to control the NI-9145 and its modules using the cRIO’s nifpga session in Python?
Thank you in advance!
(393 Views)
It is not possible. Direct FPGA-to-FPGA communication (e.g., FIFO or DMA between cRIO and NI-9145) is not supported. EtherCAT communication must go through the RT layer using the Scan Engine.
NI-9145 is supported by NI-IndusComm for EtherCAT driver. The drive is not supported by Python. You can either:
  • Find non-NI third party ethercat python library.
  • Use NI-9149 instead which can be accessed via nifpga-python
https://tmesystems.net/
(357 Views)
I searched about NI-9149 but couldn't find any resource that it is supporting nifpga library. Can you please share if there are any resource for that one? Thank you.
(346 Views)
The following links show that NI-9149 can be accessed by NI-RIO API.
Setup Guide for Ethernet RIO Expansion Chassis
Communication Between NI-9149 Expansion Chassis and cRIO Controller
nifpga-python is the python api for NI-RIO driver.
(313 Views)
Thank you for the support. My final question will be regarding usage of nifpga for the NI-9149. I posted a simple example to deploy the fpga bitfile into the cRIO. How it will be handled for the NI-9149?
(276 Views)
Similar to cRIO. The only difference is the latency.
When NI-RIO API is running on the cRIO, cRIO can access the FPGA directly via NI IP digital communication at microsecond latency.. Whereas for NI-9149, the communication is done via TCP/IP with milliseconds of latency due to network communication.
(267 Views)
