Controlling an Instrument
Hello everybody I hope all of you are well,
I have a project where I have to control an instrument, I was able to connect with VISA Test Panel and to send commands, but now I have to implement into a Lab View .vi I created a Com Port sub.vi but it seems like is not working, when I am trying to send a visa write command and I was hoping if someone look and see if matches the below screen I/O settings.
Thank you and best regards to you all.
(3,795 Views)
Accepted by MariusS
You changed your timeout from 2 seconds to 0.5 seconds.  Other than that, it all looks fine.
What device are you trying to communicate with?
(3,787 Views)
A Lesker RF power supply.
Thank you for input.
(3,782 Views)
How do you know it's not working?
Bill
CLD
(Mid-Level minion.)
(3,761 Views)
Is working, just a rookie mistake on setting string control array to code display.
Smiley Happy
(3,753 Views)
