01-24-2005 01:20 PM
01-25-2005
03:57 PM
- last edited on
11-25-2025
02:08 PM
by
Content Cleaner
Thank you for contacting National Instruments.
One good starting place for motion control is to use the Measurement and Automation Explorer (MAX) program to setup and test your motion controller. If you are using the PCI-7314 with ValueMotion 5.0.2 (latest version), then you should be able to use MAX. If not, I highly recommend upgrading to 5.0.2. Also note that ValueMotion is an obsolete product, so updates are no longer being made.
To use the motion controller in LabVIEW, I recommend first taking a look at the example programs. ValueMotion will install example VIs for simple move operations in the LabVIEW\examples\motion\ValueMotion folder.
Hope this information helps out. Let me know if you have any further questions.
Best Regards,
Jesse D.
Applications Engineering
