Controlling speed of a Video
Can someone help me in Controlling the Video speed.
I have converted the video into jpeg now I have around 600 jpeg which i need to display at a rapid speed but theirs alway sum time lag in the video,kindly if sumone can suggest anything for this.
(3,185 Views)
Accepted by anurag267
Hi anurag,
  Are you using writetoavi function?
Thanks and regards,
srikrishnaNF
Srikrishna
(3,172 Views)
Actually I was been told to convert the video into jpeg and then display them rapidly so that it appears as a video.
Problem is that I have 600 jpeg and to display them consumes time and the video does not appear to run continuously so what am I suppose to do.
Please help.
(3,157 Views)
Hi anurag,
  If you are using writeto avi function,first thing you need to consider is frame rate and codec....these two parameters will decide how should a video file should run and in which player it should run.....Say if you want 30frames per second....then each image should run at every 1/30 seconds..means your for loop should iterate at that speed...
Can you post a vi how you have done.
Thanks and regards,
srikrishnaNF
Srikrishna
(3,154 Views)
I have been given the attached file(vi)for reference
Please go through it and let me if I am on the right path..
(3,145 Views)
Hi anurag267,
  Place a timedelay Vi  and wire to 33..i.e for very 33 ms..one image is written to the picture indicator...
Thanks and regards,
srikrishnaNF
Srikrishna
(3,138 Views)
Thanks a lot I'l try it and will get back to you.
(3,134 Views)
