Controlling tab control using using boolean
I have a tab control and I want to change the visibility of the front panel pages based on the Boolean it receives. Can someone help me?
Nachiket
(4,559 Views)
Write to a local variable of the tab control.
If the tab page is always operated by the code and should not be operable by the user, make the tab control into an indicator and write to it directly with the desired value. No local needed. You can even hide the tabs.
(4,552 Views)
I am not quite getting it. I would be very grateful if you could show it in the .vi I have attached.
Thanks for the reply.
Nachiket
(4,511 Views)
I did a little code to command 2 pages of tab-control with boolean.
Regards, Fred
Kudos are welcome! Smiley Happy
(4,500 Views)
Here's what I would probably do (and hide the tabs).
(4,480 Views)
