Controls Property Array being defined as an ENum
HI,  I have an example of an event handler that I am attempting to use with my menu.  I am using the controls[] property for the VI Panel and all is well with its execution.  The problem that I have is that I am going to have lots of controls and do not like the way that I have to use strings for the case structures using labels.text to determine what control to handle.  TYpically, I like to implement enum types for controls so that the case structure compares the numbers yet displays the text for code readability.
Is there a way to systematically convert teh controls[][ property to an enum type for this purpose?
(2,652 Views)
Enum values can't be set when the VI is running, so they have to be set at edit time. You can write a VI which will extract the names of the controls into the Strings[] property of an enum and then copy that enum into your VI, but the enum will be out of date if you change your controls.
___________________
Try to take over the world!
(2,650 Views)
