I have a menu cluster of 3 booleans to do compensation on an agilent meter. See the code, the second boolean: Measure Short will not read correctly, or long enough by labview. This sounds like a stupid question, but I don't see what the problem is since I copied the button from the one above which works just fine.
Please help me, you should be able to just change the VISA to Com1 and probe the output of the menu cluster and see only a momentary blink of true.
Thanks in advance,
Acer05
