Showing results forĀ
Search instead forĀ
Did you mean:Ā
Controls Status LED / Indicator
How can I turn on the status LEDs / indicators for the vlv controls (vlv 1 through 4) in the true case ?  Need to switch to the true case have all simulated outputs active with vlv control status LEDs on and switch back to independent operation in false case.
My other programs have many valve controls and I would like to avoid local variables.
Thank You
Gary
(6,002 Views)
I think you need some thing like this
(5,977 Views)
Hatef
I have version 13, cant open the vi you sent.  I will sent to ni to have it converted or you could send me a jpeg of the block diagram.
Thx
(5,948 Views)
(5,933 Views)
Accepted by ggress1
also this is the file in LV 2013
I hope it could support this vi
(5,930 Views)
