Conversion from Excel time to labview time
Hello all,
                                   I want to convert the excel time stamp to labview time stamp. Can you all please help me how to do this ?
In my application labview time is 05-11-12 14:56:00 and its equivalent excel time representation is 41218.6222222222.
I tried this formula,
Labview time =  24*3600*(Excel time - 1460) but anwer is wrong.
Thanks.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 1 of 21
(5,411 Views)
Did you search first?
PaulG.
Retired
Message 2 of 21
(5,388 Views)
Ok, here's what I found.  The conversion is:  Time Stamp = 86400*(Excel Time - 1462).  But here's the kicker: the timestamp is GMT.  You have to add your time zone offset as well.  I'm in the Eastern Time Zone, so I had to add 5 hours.  I'm not sure what DST will do to this.  I'm sure there's ways around it, I just don't have time to look into it more right now.
Message 3 of 21
(5,387 Views)
Hi crossrulz,
                                     This logic is not working, Please try the number what i provided in the question.
Thanks.
--Ranjeet
Message 4 of 21
(5,363 Views)
Hi all,
                            What i found is that when representing the time into excel sheet. the difference between time is not constant
#1. 14:51:00 11-05-2012    ------   41218.61875
#2. 14:52:00 11-05-2012    ------   41218.6194444444
#3. 14:53:00 11-05-2012    ------   41218.6201388889
#4. 14:54:00 11-05-2012    ------   41218.6208333333
#5. 14:55:00 11-05-2012    ------   41218.6215277778
#6. 14:56:00 11-05-2012    ------   41218.6222222222
So if the difference between the numbers is not same than we cannot find any common logic for conversion.
Agree friends ?
--Ranjeet
Message 5 of 21
(5,359 Views)
There are some slight rounding issues, but the results are fine for me...
NOTE: My date is setup as M/D/Y
Message 6 of 21
(5,347 Views)
Its look like that i am committing some mistake. I also tried this but my answer is wrong. Can you please tell me why ?
One more thing how exactly you got this 1462, i think this should be 1460 ?
--Ranjeet
Message 7 of 21
(5,329 Views)
What time zone are you in? Can you attach the actual VI?
I put "1/1/1904 0:0:0" into and cell in Excel and then performed a value() on that cell.  The result was 1462.
Message 8 of 21
(5,312 Views)
Excel has two errors related to its data calculations.
1.  Day 0 is Jan 0, 1900.  Which of course doesn't exist.  Jan 1, 1900 is day 1 in Excel. (There is a 1 day error.)
2.  Excel thinks that Feb. 29, 1900 exists as a leap day, while in reality it doesn't.  (So there is another 1 day error.)
Day 0 is Jan 1, 1904 GMT in LabVIEW .  And since it doesn't have the year 1900, the presence of a leap day in 1900 or the lack thereof doesn't show up in LabVIEW's data calculations.
Message 9 of 21
(5,302 Views)
another one.
Time to XL can be downloaded from here https://decibel.ni.com/content/docs/DOC-19689
as well as it's inverse XL to Time
Significantly Excel epoch is dependant on the OS system time zone (Yes, it is insane 0 means midnight on the 0th of January 1900 local time) and there is the famous leapyear bug Microsoft copied fron Lotus)
Don't forget to vote
Message 10 of 21
(5,295 Views)
