Conversion of LabVIEW 5.1 code to 8.5
Why didn't you simply start a new thread as requested?
Message 61 of 102
(2,802 Views)
I am sorry about the that.
Actually, I am new here, and could not figure out how to add a new thread in this forum. The only way I found out that I could say something was the 'reply'.
Jiwei
Message 62 of 102
(2,796 Views)
     Good afternoon,
I have installed Labview 8.5 on my computer, it does not allow me to open source code made in LabVIEW versions 5.1.1 and 4.0.2, the error message that appears when I try to open the source code is: version 5.1.1 (4.0.2) is too old to open in 8.5.  Please, is there someone who can help me? May I compile the source code in some way...
Smiley Sad?  Mike, could you help me if I send you the source code?
     Many thanks in advance.
Message 63 of 102
(2,764 Views)
I am not Mike. You might go to http://forums.ni.com/ni/board/message?board.id=170&message.id=339255&query.id=21211#M339255, and click the "reply" above "Mike", but not my name.
Jiwei
Message 64 of 102
(2,758 Views)
Hi Jiwei,
sorry! and many thanks! I have sent to Mike my post.
Message 65 of 102
(2,747 Views)
Hi Mike
I have the same problem as all the others in this thread. Could you please convert my drivers also (to version 8.6 or 8.5) or else tell me what I need to do? I enclose two zip files with the relevant drivers
Thanks very much and best regards,
Rick
Message Edited by locktofer on 09-24-2008 11:45 AM
Message 66 of 102
(2,628 Views)
Hey Mike, I have the same problem, i.e. labview 5.1 software for an HP 4274 LCR meter and I have labview 8.6--I can't open the llb. I'm including it. Can you convert it for me? Thanks.
Message 67 of 102
(2,388 Views)
Hi Specfiction,
here is the converted library.
The LV 5.1 is not supported anymore.
If you have licence for 8.5, you can install older version with this SN. Enough for this conversion is LV 7.1
Jiri Keprt
AE
NIE Czech Republic
CLA, CTA
Message 68 of 102
(2,346 Views)
Thanks Jiri Keprt.
Message 69 of 102
(2,315 Views)
Hello everyone,
As LVO, i really need to convert some VIs from Labview 5.1 to 8.5, could someone please help me to do it.. the file are available to download in this website http://www.dieterb.de/ccdlockin/index.html
ps : could you please send me an email to notice that the files were converted.. raphael.baltar@hotmail.com
Thank you in advance,
Raphael Baltar.
Message 70 of 102
(2,208 Views)
