Conversion of VI in WinXP to VI in WinCE
I have a VI with LabVIEW 8 that works on Microsoft Windows XP/Vista/7.
I want to design an ARM based system that can run Microsoft Windows Embedded CE (I know ARM9 and ARM11 can do it). I want to use ATMEL SAM9G45 ARM9 Board which supports WinCE.
Is there any way I can convert my VI on Windows XP/Vista/7 to a VI or program on WinCE without any need to major changes?
It is preferable that this conversion keeps the same front panel.
I installed LabVIEW 2011 and Embedded Module for ARM Microconrollers. But it just converts the VI to some ARM microconrollers that I think does not support WinCE.
Any help.
Ali,
Thanks.
(2,281 Views)
http://zone.ni.com/devzone/cda/tut/p/id/4577
You can do this but I think it may require a PDA module that isn't free.  I would call NI to be sure everything will work with your hardware choices.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,274 Views)
