dsc
I am a newbie to LabVIEW. Can anyone tell me how to find if the DSC Module is installed or not. I am trying to connect labVIEW to CompactLogixL23E Controller through ethernet and during the Topic Configuration in LabVIEW 2010, I selected a New Proejct and  when I right click on My Computer and select New , the drop down menu doesn't list I/O servers. When I checked into NI forums someone suggested that DSC Module is probably not installed. So is there a way to find out if it's installed or not. Please help me in this regard.
Sunil
(3,388 Views)
The DSC module doesn't come for free... Saddly... And to see if you have it installed just go to the Tools menu, not far from the top you there should a DSC Module item with a few sub-items, if not, then it is not installed...
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,381 Views)
Thank you very much for te help. Can you also please let me know if it possible to  create any tags(how to read /write I/Os from a controller) in LabVIEW without DSC module.
Sunil
(3,375 Views)
It depends what the other device supports but ModBus is often a good solution, NI gives for free a ModBus library.
Hope this helps
Epictetus
Antoine Chalons
(3,371 Views)
Hello, What device are you trying to communicate to? Is this a PLC system?
To communicate to I/O devices often times you need the OPC server either from the manufacturer of your product or from National Instruments, the OPC server from NI is a very robust server. In the other hand. You will also need the DSC module or Data socket in order to communicate via OPC. Server Client is what we look for.
Luis A.
Applications Engineer.
NAtional Instruments.
(3,360 Views)
