Conversion of acceleration to displacement for vibration
Dear J Thomas, thank you for your kind answer.
A look at my very simple VI (attached as "prova_integraz1" in my last post) will confirm that I had already tried to modify the highpass cutoff frequency, by setting it to 0.001.
The problem is that curves keep being very different about the shape and the values they take!
I'm using an accelerometer whose nominal lowest frequency is around 1 Hz (I think it is 0,7Hz, according to the datasheet), but I was first willing to understand the way SVL integration works 🙂
Message 21 of 26
(2,367 Views)
Your approach is perfectly correct, if the mean acceleration were not zero, the object would be (in average) accelerating and moving from its rest position! In fact, piezoelectric accelerometers cannot measure zero frequency acceleration (steady acceleration) so the mean of the signal has to be zero. For the same reason, you can set the mean velocity to zero when integrating to displacement. Another approach to avoid drifting is to integrate in the frequency domain.
Hope this helps
Message 22 of 26
(2,123 Views)
I am trying to get displacement RMS value from a signal obtained from an accelerometer. This accelerometer is connected to a shaker that vibrates at 159,2 HZ with an acceleration RMS value of 3,16 m/s2. At that frequency it's supposed to obtain the same RMS value for velocity (3,16 mm/s) anf for displacement (3,16 um).
I have used the SVT RMS level.vi using the signal obtained from accelerometer as input. I obtain the correct aceleration RMS value. Then I double integrate that signal using SVT Intgration.vi and apply SVT RMS level.vi, but the value I obtain doesn't mach with the expected one(3,16 um).
Should I eliminate DC componet of the signal before integrating it?  Or before using SVT RMS level?
Message 23 of 26
(1,978 Views)
can you explain with some example?
Message 24 of 26
(1,392 Views)
There was code posted in this thread. If you go back a few messages (it appears on the second page for me), there is a post date/time ‎01-28-2008 05:09 AM with prova_integraz1.vi attached. That's the code that the users were discussing in this thread.
Additionally, this thread is older (original post 2007, last post 2009). You may want to create a new thread that references this conversation to get more traffic flow. There is a chance that the users on this thread are still subscribed, but it's hard to say.
Taylor B.
Message 25 of 26
(1,370 Views)
Also, if it is the actual physics behind the conversion from acceleration to displacement, I did find this website:
http://www.cbmapps.com/docs/28
Personally, I'm not familiar with the physics behind this conversion.
Taylor B.
Message 26 of 26
(1,365 Views)
