Conversion to decimal string from I32 - coercion dot in case of array
Probably the answer is trivial, but I do not get this 🙂 If we have the same data types, why a coercion dot appears for arrays?
Message 1 of 8
(5,328 Views)
Interesting, i haven't thought about it before, but it does! Not only on I32, but on all arrays! My first thought was that it changed to some other data type, but no number format works, and an array of variants breaks. Maybe it coerces to an Array pointer or something?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 8
(5,318 Views)
The conversion works. But when I see a coercion dot plus I do not know why, it makes me a tiny bit worried 🙂 So very interested what the red dot means in such cases...
Message 3 of 8
(5,312 Views)
I remember this being brought up sometime in the past.  Perhaps it was during a beta.  Don't remember if a CAR came out of it.
Message 4 of 8
(5,289 Views)
Accepted by Blokk
Hi!
the behaviour is filed as CAR 152788 'Coercion Dot appears when wiring Integer Array to Number To Decimal String.vi' and is not yet fixed.
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
Message 5 of 8
(5,249 Views)
Hi Christoph,
so that problem most have a very very low priority as the coercion dot was already shown in LV2009(SP1)…
(That's the oldest LV version I have in use right now.)
Message 6 of 8
(5,244 Views)
Hi Gerd,
I can neither confirm or deny that Smiley Very Happy
Understandably that is not most pressing issue.
Christoph
Message 7 of 8
(5,235 Views)
@Christoph_D wrote:
Hi Gerd,
Christoph
Do not worry! I have found a temporary workaround:
Message 8 of 8
(5,230 Views)
