Convert 0 to "fail" and 1 to "pass"
Is there an easy way to convert the numeric, 1 to the string "pass" or convert the numeric 0 to the string "fail"?
Message 1 of 14
(5,009 Views)
Use a case structure, but be sure to wire up a default case!
Message 2 of 14
(5,006 Views)
 You could use a case statement with the numeric as its selector.
EDIT:  D'oh, a few lousy seconds.
Message Edited by OlderJohn on 03-24-2009 01:59 PM
Message 3 of 14
(5,006 Views)
Accepted by chuck72352
This is a simple way, you could also use a case structure if more code is involved.
Ahh, got beat on the case structure!!!
Message Edited by Chris_VH on 03-24-2009 02:01 PM
Chris Van Horn
Applications Engineer
Message 4 of 14
(5,001 Views)
Be careful if using the DBL datatype, I don't know where the 0 and 1 are coming from but you made need to build in a tolerance with that equal function.
Message 5 of 14
(4,996 Views)
Very valid point, I just created a control off the function. I was trying to race for first reply! Smiley Very Happy
Chris Van Horn
Message 6 of 14
(4,990 Views)
Here's a Select with an integer input.
Message Edited by Dennis Knutson on 03-24-2009 01:04 PM
Message 7 of 14
(4,987 Views)
Thank you, I was looking for a method other than using a case statement.  Your suggestion works well for me.
Chuck M.
Message 8 of 14
(4,973 Views)
I wasn't aware that a string could be wired to a "Select" function.
Thanks again.
Message 9 of 14
(4,949 Views)
just want to mention the "Append True/False String" function (which has a boolean case selector) Smiley Wink
Message Edited by GerdW on 03-24-2009 08:16 PM
Message 10 of 14
(4,948 Views)
