Convert 1024 to 1KB like "%.2p" SI conversion
Hi
Is there a function or feature that will convert an integer or double value to an SI equivalent decimal string, but using 1024 as the divisor?
I.e
2^10 = 1024 (K)
2^20 = 1048576 (M)
2^30 =  1073741824 (G)
Etc
In other words -
0 < N < 1024 = "N"
1024 < N < 1048576 = "<N/1024> K"
1048576 < N < 1073741824 = "<N/1048576> M"
ETC
I'd be surprised if such a function does not exist. Or am I being naive?
Message 1 of 8
(2,427 Views)
I don't know if it exists, but it's really not hard to do by yourself:
Message 2 of 8
(2,403 Views)
Use an array of "",k,M,G,T and look up quotient of Log2(x),10 as the index.
Format "%f %sB" where f is Remainder log2(x), 10 and %s is the string from the Lookup table
Message 3 of 8
(2,393 Views)
That won't do it.
This kind of works, but the result is funky if the input is < 1024.
Message 4 of 8
(2,379 Views)
This works for practically anything, but i don't really like how it handles the decimal points.
JPB's idea, but i couldn't get his to work with the Remainder Log2(x), 10, so i did x/(1024^(log2(x)/10))
Message 5 of 8
(2,366 Views)
Well, that would be because I failed to describe the conversion correctly.  CERTAINLY this was a problem with trying to type from my phone and not a failure to properly think through the math 🙂
I don't understand why x is not a Unsigned Integer in AeroSoul's picture of a snippet Last I checked Bytes can't be negative or fractional.
Message 6 of 8
(2,345 Views)
Minor mod to add coverage for Peta and Exa (Zetta and Yotta are ignored since a U64 0xFFFFFFFFFFFFFFFF is a mere16EB-1Byte.)  We need P and E to prevent indexing past the array size and making large numbers look small
Message 7 of 8
(2,319 Views)
Because right click--> create control on the log2(x) makes it a double 😄
Message 8 of 8
(2,240 Views)
