NI MAX is not responding.
When I am try to open NI MAX, under remote systems NI-cRIO9074 is showing properly but when I am clicking on devices and interface under cRIO9074, then NI MAX crash reporter dialog box is showing and automatically close the NI-MAX. What should I do? Kindly tell.
attachment is shared.
(2,518 Views)
I am unable to run Native access on my MacBook Pro (Big Sur - 11.6). When I install it and try to open the application, it says "Application not responding". Yes, I have enabled it in security settings, yes I have tried restarting it, and yes I have tried uninstalling (including deleting the appropriate files in Macintosh HD) and reinstalling it. Why is this not working? NI says the system is compatible and I don't have issues running any other software (i.e. Sibelius, Max/MSP, Ableton, etc.).
(2,456 Views)
Could you please specify the Cseries module pluged into the cRIO- 9074, Reset NI Max configuration data ,
you find below the required driver for your compactRio :
the last version compatible to your compactRio is 2019.
 Best Regards.
(2,443 Views)
I suggest that you would need to debug following the steps stated in the link.
Here’s the link mention that what you can do when NI MAX is crashed.
(2,338 Views)
