Convert 1D array output to boolean
Hi, I need help. Im trying to make a login page, and I am using an array to stock the user emails and passwords, and using this inside of a for loop, so, I need to compare that array with the user insertions, but I have a problem because, the software show me this error:
"You have connected two terminals of different types, the type of the source is 1D array of boolean(TRUE or FALSE), the type of the sink is boolean(TRUE or FALSE)". Here is a image: Captura de Pantalla 2021-08-12 a la(s) 11.22.09 a. m..png
What can I do?
(2,814 Views)
Hi Jhonatan,
you are testing two items of "Correos" for being equal to "Usuario": what should happen when
  1. none
  2. the first
  3. the second
  4. both items
are same?
Once you answer this question you can decide to use an AND or OR function to reduce the array of booleans to a scalar boolean…
Btw. you might learn about autoindexing at loop borders to simplify your VI!
(2,803 Views)
I assume that the array has two elements and cannot change during the loop execution. Similarly, the scalar cotrnol os also loop invariant. Thus both controls belong before the loop.
The entire loop can be replaced by a "search array" function. You get -1, 0, or 1 as possible output, depending if none, he first or the second element is equal.
NOTE: you'll get much better help if you would attach your actual VI. Many things cannot be determined from a picture (e.g. the size of the string array, the default values for the controls, etc.)
(2,788 Views)
Here's how that could look like. See if you can recreate it:
(2,782 Views)
